PME2018
- New Hamshire
- Master Electrician/Electrical Contractor
If I am bidding a job using the plans put forth from the lighting design firm via the architect, and several of the loads on the project require 0-10v dimming provisions, but nowhere on the plan is this detailed or outlined, nor is there any reference to whose responsibility it would be to supply and install the 0-10v low voltage cabling (whether it’s the EC or Low Voltage System integrator) Also there is no single line diagram detailing 0-10v cabling requirements, and is only noted within the individual lighting spec sheets of which fixture types are 0-10. Now with all that said, who’s running the 0-10v low voltage dimming cable, the EC or the Low voltage control contractor?
Thank you.
Thank you.
