wwhitney
- Berkeley, CA
- Retired
I think we already went through the math at the level of waveforms for computing V(A-B) as V(A-N) - V(B-N), yes? That was for V(A-N) and V(B-N) of equal magnitude and 120 degrees apart.Sorry, but I am a little hard-headed, or persistent, if you think positively. Is it possible for someone to create a combination of waves that expresses what happens when output from A-B inverter and the output of B-C inverter combine in N-B?
Well, for your question, which is the last 3 paragraphs of post #288, the current going into node B will be I(B-C) - I(A-B); the minus sign on I(A-B) is because that quantity is the current going out of node B to node A. And I(A-B) and I(B-C) are of equal magnitude and 120 degrees apart.
So the math is exactly the same as what we saw earlier for computing V(A-B).
Cheers, Wayne
