Electricallearner
- tuscon Az
- Engineer
I kept getting wrong values, and finally found the solution online.
Derating value x ampacity value
Derating value for 8 conductors = .7 (Table 310.15(B)(3)(a))
Ampacity value for #10 conductor in 75C column = 35 (Table 310.15(B)(16)
This gives the correct Answer of 25Amps -
So for this problem I have couple of questions.
1) The questions states THHN conductor - And in NEC 2017 - Table 310.15(B)(16) - 75C Column - there is NO mention of THHN insulation- and instead NOT use 90C column - which clearly includes the THHN insulation.
2) It says ambient temperature of 100F - so why don't I include this in the calculation and use Ambient Temperature Table 310.15(B)(2)(a)? Instead JUST use Table 310.15(B)(3)(a)??? I thought it's imperative to use the Ambient Temperature Table.
3) Finally - why don't I multiply times 8 - The question clearly says (... the ampacity of 8...) LOL
Any help - cause I feel like I am missing some obvious information, or this question is poorly written. Now I am worried about how to do these on the actual exam?
THANK YOU!!!
THANK YOU!!!
