Hi All -
I am planning to take the Electrical Construction Exam.
I am not sure what will be the percentage of questions related to Calculations/Math vs finding the right Information/Definitions.
Also, as far as the math questions are concerned. Knowing that each question is worth the same, would you say there are more of the harder math questions, which require more time or easier (one or 2 step) calculation questions?
If someone can share their experience, I would really appreciate it.
Thank you!
Hey, Electricallearner
Have you had any class room training or face to face with a qualified Code instructor?
That is to say, just you and the instructor and no one else to create a distraction.
I'm talking about someone who can sit down with you and explain the art of test taking.
Is this a two part exam, or one part? Doesn't matter.
What exactly is the
Electrical Construction exam? Simply an exam focused on the Code?
Don't worry about the
percentage of questions. Or, there point value.
A lot of calculations type questions have multiple steps to take to get the correct answer.
So you must be cautious that you do all required steps to get the correct answer.
Because if you don't, you're likely to have two or three answers consisting of a 3 or 4 step formula.
And only one real answer
based on all of the necessary step one two etc.
Those are called distractor answers. Also, use 'guesswork' never leave an unanswered question.
Yes, you will likely need to be up to Code with your math. Find someone who maybe
qualified.
If you can't find that 'someone,' don't let that stop you, forge on and keep studying! I'm talking
seriously studying.
If this is your first or 3rd or 4th attempt at the exam, go
take it with I'm 'gonna' learn something each time I take the test.
It just may work. One of the keys is to study, study and more studying. Oh, did I tell you to study?
chuckle
And find a mentor, someone that shares your same interest in passing an electrical exam.
Don't stop 'till you pass! Don't let someone try to tell you that they have taken the test 10 times and still failed! Ignore it.
Let me know your progress as you continue.
Thanks for reading
Comments accepted
TX+MASTER#4544
