Seven-Delta-FortyOne
Goin’ Down In Flames........
- Humboldt
- EC and GC
Where does the tap go? I assumed they landed on that back fed tan handleThe taps with no OCPD
You just don't see any ocpd.The taps with no OCPD
Awww, come on. If we put our heads together we can find SOME code violation. Hey! The conduit coming through the back, it cut out part of the required labelling. That must be what you saw and just forgot.Huh!
Looked at that picture 3 times and thought it said something completely different.
What an idiot. Guess I didn’t need to plan on installing a new breaker.
This is what I get for giving up drinking for Lent.
That’s not minor. I have a picture of a TA cutting a big slice into a conductor.No bushing on the PVC adapter?![]()
I see a third conductor coming down, in front of the neutral, and going into the panelboard. Probably the neutral.I do not see a neutral conductor going into the CH panel. I see the two taps, and a green ground.
