xguard
- Baton Rouge, LA
Isn't that what I said?My guess is that it is not rated for a corner grounded delta. I bet it sees the ungrounded to grounded voltage as a line to neutral voltage that exceeds the line to neutral rating of 350 volts.
I luckily did not, but the electrician who wired it up did connect the neutral.Did you connect the white wire to anything?
The instructions show no connection to the white wire when installed on a delta system.I luckily did not, but the electrician who wired it up did connect the neutral.
Are the MOV's in the device typically arranged in a wye configuration?
Very specific about it.The instructions show no connection to the white wire when installed on a delta system.
