LarryFine
- Henrico County, VA
- Electrical Contractor
I'm suggesting that, for interior lighting, yes; for general-use, fused switches, and the like, no.Isn't a neutral always required to be run with a switch loop, unless the wiring method is conduit?
Interior lighting switch boxes needs a grounded conductor for occupancy sensors, timers, etc.
Other switch boxes need them if the switch itself does, or if the load is fed through the switch.
