Alwayslearningelec
- NJ
- Estimator
From your experience what would take longer? to bend a 4" 90° or use an elbow pre-manufactured? Thank you
Which is likely to be necessary either way, at least on one leg. The factory elbow saves layout time, too.Seemingly there might be more to the question. If you use a factory 90 are you going to have to cut & thread the adjoining stick ?
Well that's a money maker in either case. However, if I was trying to trim a bid for competitive reasons I would be adjusting this down.Well I included bending in my estimate and it gave me 3 hours per 4 in bend.
Gotcha I just don't know if the guys in the field are going to use prefab elbows or bend. I have about 10,000 ft of RGS. It consists of about four to six four inch pipes in each run. I put in bending cuz I wasn't really sure what would determine if they would use prefab elbows. It's all overhead runs at about 25 ft. Wide open space being supported by trapeze racks.Well that's a money maker in either case. However, if I was trying to trim a bid for competitive reasons I would be adjusting this down.
One determinant is whether factory elbow angles are suitable.I put in bending cuz I wasn't really sure what would determine if they would use prefab elbows.
What do you mean?One determinant is whether factory elbow angles are suitable.
Whole different ball game, you will need the 3hrs per bend to compensate for other difficulties.Anyone familiar with using PVC coated RGS? Can you bend that at 4" or you need to use factory elbows?
No it's about 3,000' pvc coated and 7,000' RGS non coated.10,000 ft of PVC Coated 4: RGS.
More power to you. I can't tell you how nervous I would be with that bid.
Hopefully you have some dang god journeyman and a lot of Ben-Gay.,.
