We have an 80amp 3ph 120/208 receptacle that we are installing outdoors. We are on the 2023 code which requires the GFCI class A protection for up to 100 amps. This has been in the NEC for 8 years so I thought these products would be readily available by now. I am not having any luck.  I could not find a breaker for our GE panel nor a device that we can wire in like the Littelfuse short block which can not be used with a neutral.   Can any of you point me in the right direction? Do I ask for 90.4(D) forgiveness?
