WireNut311
- NJ
- Electrician
For above ground pools you have to hit 4 posts for the bonding. Is there anything in the code that says the joint plate where the walls of the pool are bolted together have to be bonded?
The pool is filled, and my only fear is if I take this support post off to expose the plate with all the bolts I won’t be able to get it back into place because of the pressure of the water. Was going to call the inspector, but I figured I’d ask you guys first.
