Better off with a kholer I'd say.I have a feeling that if you have a Generac and a month long power outage you will be replacing it soon after.
-Hal
Residential generators have been here for 25+ years but only the last 7 in a big way
They take a lot more maintenance than an AC system for sure. I would guess about 50% are maintaining them, the rest wait for a crisis and call everybody in the book. Air cooled generators are cheap and unforgiving of poor maintenance but it gets the bottom line down so that is what everybody buys.
But can require large tanks or a vaporizer where the tank is installed in areas where is gets cold.Propane is a common fuel where natural gas is unavailable.
Or when a bullet hits it on 4th of July fireworks?So, how do you sleep at night with a 350-gallon propane tank in your backyard ? And what do you do when a forest fire is on its way ?
On syrup mills, they light a fire under the tank to get the last bit of propane out to finish the last batch of syrup. Farmers don’t put any more in until next year, because the tank shut off valve tends to have a small leak, and drains the tank before the next year. Usually the high pressure pop off valve will release the gas, and it will burn off there if ignited. Not that common for them to explode unless somebody is doing something really wrong.So, how do you sleep at night with a 350-gallon propane tank in your backyard ? And what do you do when a forest fire is on its way ?
A bullet will not set them off anyways. I have shot plenty of what I thought were empty tanks, and they never exploded.Or when a bullet hits it on 4th of July fireworks?
Most of the Residential generators employ basically a tractor engine. Not something I would use for critical life support.Residential generators have been around for some time now, I'm curious as to how they've been holding up.
Have they proven to be reliable?
Are most owners performing the necessary maintenance?
