- Chapel Hill, NC
- Retired Electrical Contractor
Can the conductive frame be touched by anyone post install? Usually I would see a metal top rim edge that the metal framing connects up to. If yes I would bond. Added safety minimal added cost. Newer code than the 17 has clarified and limited what some are calling a storable pool and the non-bonding of it. Some had considered the above ground pool as a storable because it can be dismantled and are drained down for winter, but 23 seemed to clear that up.
Yes, they did away with the 42" definition in storable pools. They also moved it out of art. 680 and into definitions.
Pool, Storable; used for Swimming, Wading, or Immersion (Storable Immersion Pool). (Storable Pool)
Pools installed entirely on or above the ground that are intended to be stored when not in use and are designed for ease of relocation, regardless of water depth. (680) (CMP-17)
