gfci afci protection
am i reading the code correctly that 210.8(D) states electric ranges need to be gfci protected? Why wouldnt a water heater require GFCI protecction?
if i had a hardwired appliance. say a two pole 20amp unit heater...that wouldnt require afci protection? because its 240 volts between phases?
the potential hazard for an arc fault isnt justified for this installation because.... why? its not cord and plug connected? thank you for your incite
I don't know why and I'm glad it's not.
AFCI protection is only required for 120 volt outlets. Not 120/240v or 240v outlets.
Ron
Don't worry there's next code cycle for it to be required. Then it will be the whole house.
And then I'll have to get a gasoline powered daily driver because my EVSE trips the breaker that's required for the receptacle that I don't want to hardwire my charger into.
The first draft of the 2026 code 625.54 says all outlets that supply EVSE must have GFCI protection, so hard wiring wont change anything if that makes it through the process.
Time to buy a different car!
Or move to Key West so I can just ride my motorcycle or bicycle everywhere.
I want to know how many people are actually being shocked by improperly installed EVSEs because they’ve always had their own integrated GFCI.
From what I have heard, the ground fault protection in the charge controller is equipment level, not personnel level. Probably why they have a lot of nuisance tripping.
