cgamad550
- United States
- Apprentice
Hello guys I have a question. At my grandmother's house she had an old sub panel box that was probably installed 30 years ago.
She had issues with lights flickering ECT.
I seen the sub panel only had 3 wires coming in. 2 hots and bare neutral.
So I installed a new Square D homeline 100 amp sub panel and pulled #2 Copper and sperate Equipment Ground Conductor and also separated the neutrals and grounds
Installed all new Homeline breakers.
However now the flickering light have gotten worse.
I went out and took a good look at the service entrance panel and this is an very old Square D QO panel no main disconnect just 2 hots coming in from the meter can to main lugs and also a bare Aluminum stranded wire however I noticed that the neutral wire coming in from the meter is not twisted hardly at all all the stranded appear loose.
My question is could that Bare Aluminum Neutral/Ground being loose and not twisted tightly together be the issue for the lights flickering. I've heard it could but wanted to check with some other electricians to verify this and if so the best way to twist this wire and I've never worked with bare neutral service entrance wire before I've also used the insulted ones.
Thanks in advance for the info.
