Ephraim.Barlow
- Colorado
- Electrical Design
It seems as though our industry is still grappling with the new regulations concerning Automatic Receptacle Control in Offices and Conference rooms. The IECC Code states in part "... At least 50 percent of all 125V, 15- and 20-amp receptacles installed in enclosed offices, conference rooms, rooms used primarily for copy or print functions, breakrooms, classrooms and individual workstations, including those installed in modular partitions and module office workstation systems. ..." - IECC 2021 C405.11
My Question is: Is there options out there for controlling multiple circuits in the same room or work space with one control device? e.g. There is four workstations in one bull pin area in the front lobby of a small clinic, three or more circuits will be needed to supply power to all the workstations in the area. Under the IECC code listed we will need to control at least 50% of all receptacles in this area no matter what circuit they are associated with. My thought is that the simple solution is to install a 4th circuit with only controlled devices and install 50% of the devices in the area on the one circuit. The reality is that nothing important or permanent will be plugged into the controlled devices because they will turn off each time there is not someone in the area for more than 20 minutes. But is this the intent of this code? Probably not? What is the actual thought process behind this code requirement?
