Stevenfyeager
- United States, Indiana
- electrical contractor
For 50 amp Tesla charging, ok to use a normal 50 amp range outlet ?  I see some on line advice otherwise.  Thank you.
			Also Tesla and ChargePoint both say do not use Al wire in the installation instruction.Also note none of the heavy duty EV receptacle I have seen are listed for aluminum wire.
Agreed. Otherwise, almost every house in America would not qualify.I believe that relates to the terminations on their direct-wired units. It doesn’t mean that no portion of the circuit can use AL.
In store or online only?Home Depot is now carrying charger rated receptacles.
I seen it in store, may not be all stores.In store or online only?
Thanks
I priced it out on a 60' run by the time I buy the insulated AL to CU multi port tap connectors, the chair lugs for the existing panel neutral bar and a jbox large enough to house the taps, a run of copper NM cable is more cost effective, also for me these are going into existing residential panels that can be quite stuffed so the smaller the wire the better.I believe that relates to the terminations on their direct-wired units. It doesn’t mean that no portion of the circuit can use AL.
