Jaybone812
- South shore. Massachusetts-2023 NEC
- Commercial & Residential Electrician
A word of caution here. If you run your 12 gauge conductors to a fused disconnect and use a 25 amp breaker in the panel you will be in violation. If you use a non fused disconnect you are covered just right.
Explain why it’s a violation to used a fusible disconnect if he uses a 25 amp breaker and what code rule prohibits that
