chevyx92
- VA BCH, VA
Does anyone see an issue with using this set up to control a Mechanically Held contactor? One 3-way switch with 120V on the common terminal, one traveler terminal connecting to the "Common" of a DPDT rib relay and the other traveler terminal connecting to the second "Common" of the DPDT rib relay. Then from the rib relay, one "NC" contact will connect to the "Latch" terminal of the contactor and the second "NC" contact will connect to the "Unlatch" terminal of the contactor. I just want to make sure I am not missing anything with this configuration. I know I could use a double throw center off momentary switch and do the same thing.
