ModbusMan
- Cleveland, OH
- Building Automation Engineer
Well poop on a stick... if an AFCI breaker will trip because of loads on a completely different circuit, then what the bug are the things even good for in the first place!?! I don't have much hair left to pull out, and if chasing down my misbehaving fridge circuit means pulling out every single device in the house looking for a floating ground (which was the cause behind a two-bedroom MWBC tripping every time I turned on the kitchen lights immediately after the panel swap)... aaiieeee!!!The Arc signature could be coming from any source not just the tripping circuit, just the load needed to be present.
Had random tripping on a Siemens panel that was found to be linked to a cheap Chinese unlisted junk the HO was using that was back feeding dirty signals into the system and what ever circuit was "loaded" it would trip.
