Joe.B
- Myrtletown Ca
- Building Inspector
That's the trend we're seeing here as well. I just did an inspection where every single breaker was DF. Raised my eyebrows, but that's not my business. Meets code minimum, sign off, done.The receptacle is required to be AFCI protected so why not just change the breaker to a DF?
We stopped using GFCI receptacles in the kitchen and anywhere else GFCI and AFCI is required. DF breakers are less expensive than and AFCI breaker and a GFCI receptacle. Labor is less not having to install a GFCI receptacle. Much easier to guide homeowner through resetting a breaker than trying to have them figure out which device is tripped.
