Sorry for the delay in responding, been away for a minute. I see there are few more posts on this topic,
I forgot to mentioned that your 'photo' example of the perpendicular to the framing members really doesn't mean anything as the code says what it says. I also can argue if you take a certain view with my run, then I can argue that they make straps and hardware (uni-strut etc..) to support the conduit in the picture you gave.
Like I said, I view
'readily' is being almost existing and not needing cross bars or wood or other installs to put a support. lol. I have attached a picture of an existing run that was done by someone else and was inspected and approved as I was told. The short piece of conduit is less than 2ft between boxes. I plan to do a run like this in the same area when I add my receptacle. ;-) Yes, I know they make straps just for cross bars and able to attached to the studs, and yet I am being a
REBEL
and just leaving it hanging in free air, my less than 2ft stick (about 18 inches) of emt run.
By the way, what is your definition of '
readily'?? Mine is taken in part from the NEC definition of readily accessible (not need tools or ladders ). So It doesnt 'readily permit, cause I need tools and special install construction to support it. LOL.
