Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
Within a PV fied inverter i found 0.2 ohms between 3/3 phases A,B,C from individual inverter ac output buss.
The output buss start at open contactors and individual fuses, so anything upstream is not relevant.
Then each 3/3 bus teeminate to the primary of an MV 3630 kva Y Delta transformer without any primary disconnect to sepporate the buss from transformer primary windings
I initially thought an impedance of 0.2 ohms was too low or may indicate a short eithin busses but when i did the math, this value corresponded to my meter reading of 0.2 ohms.
Does seem correct?
3,630 KVa transformer
Primary voltage 690
3 phase
See math computations in pic. Thanks
Does seem correct?
Primary voltage 690
3 phase
