wwhitney
- Berkeley, CA
- Retired
But as the grid itself has some impedance, if you measure the voltage at the inverter terminals while it is exporting power, and then tell it to stop exporting and measure voltage again (quickly enough that no grid fluctuations occur), the 2nd measurement will be lower than the 1st. So the inverter does have to put out a voltage that is higher than the voltage it sees at its terminals while not exporting power.I didn't say it could be lower, just equal.
Cheers, Wayne
