- NE Nebraska
- EC
How about a rivet nut? That would give you lots of threads and good contact to the panel.
Does it need to be? Regular bolt and nut isn't either.Listed as a grounding and bonding connection?
I guess I'm not certain what is meant by "rivet nut". If something you still thread a bolt/screw into how is that different than regular bolt/nut.? If depending on this rivet for electrical continuity I can see listing being necessary but if only providing mechanical securement I don't see it needs to be. Either way you still need a listed lug or other terminal under the bolt head, nut, etc. and remove any paint or other insulating material so you have a good bond with the metal enclosure. If you can achieve the "two threads" into the metal then that is presumably sufficient bonding contact area and shouldn't need to remove paint.
