hbiss
EC, New York NEC: 2017
- Little Falls, New York NEC: 2017
- EC
For chlorine to work properly the PH and total alkalinity have to be right also. My nieces' husband works for the health department and I bought this house and pool last year, I asked him to test the water when I opened the pool this spring. Then I got the same drop type test kit (less some tests that I would never use). He tests everything applicable to the public pool he's at.Have no idea if they tested PH levels. Pretty certain they tested chlorine levels but that may been about all the health dept cared about.
For giggles, I tested the PH of the tap water here and it was above 9 (the test only goes that high). 9 is alkaline. I guess I should keep that in mind when adding water to the pool that should be between 7.5-7.8.
Years ago in my old house I always had green stains from the water. Then they switched sources from one aqueduct that served NYC to another. (We were entitled to take water from those aqueducts since they went through our town.) Problem went away.
An acid type shower, toilet and urinal cleaner. Contains hydrochloric acid. Takes it right off. Use gloves.Blue residue in toilet bowl? what they use to clean it with?
-Hal
