You do realize we see forward and reverse kW through the meter, right?Not if they don't know![]()
Are the transmission charges also included? They are separate on our bills, and almost as much as the usage charges.ahh good catch.The fuel surcharge added would put my bill around $165/mo, so, double.
I love how they word this in the rate schedule.....
What it should say is, "...Will be increased under the provisions....in the manner we've lobbied the Georgia PSC for..."
Solar would never pay off for me, Iâm running two totally electric houses (both occupied) my highest bill is $250 a month total.
I could do hydro, if the government would allow me, which is much cheaper, but still wouldnât have a good ROI.
Maybe yours do, but national grid's meters do not record forward and reverse it's just a basic bi-directional meter.You do realize we see forward and reverse kW through the meter, right?
Here where net metering is relatively simple to do I still occasionally see a old rural PV system from back before it was.I have no interest in net metering, only offsetting my grid usage. I would like to give as little money as possible to Georgia Power.
How is that? If I'm using 1,000 kW-hr per month and install a $50K system that drops me to 100 kW-hr per month, that's very different than if I use 2,500 kW-hr per month and install the same system and drop to 250 kW-hr per month. Even though in both cases my reduction is 90%, the dollar value of the avoided costs in the second case is much larger, so my payback period in the second case is going to be much shorter, no?Payback length does not change with usage (except for a little bit of economies of scale installing a larger system)
What prohibitions do you have for hydro? Are you talking about daming up a river and that sort of thing? I would think from a utilities perspective it shouldn't matter, although controls for hydro are probably not as readily available as for solar.
If it truly is, itâs due to be changed out.Maybe yours do, but national grid's meters do not record forward and reverse it's just a basic bi-directional meter.
In Georgia we have a law that requires a 50â undisturbed buffer along all creeks. They made the law to keep people from building on creeks and rivers. The only exception is farmland. MicroHydro doesnât require a large dam.Payback length does not change with usage (except for a little bit of economies of scale installing a larger system)
Your numbers don't make sense. In the first case the system is making 900 KW hours per month, and then in the second case the same system is making 2,250 kilowatt hours per monthHow is that? If I'm using 1,000 kW-hr per month and install a $50K system that drops me to 100 kW-hr per month, that's very different than if I use 2,500 kW-hr per month and install the same system and drop to 250 kW-hr per month. Even though in both cases my reduction is 90%, the dollar value of the avoided costs in the second case is much larger, so my payback period in the second case is going to be much shorter, no?
But the value of Y depends on your local electricity rates, and whether you have net metering or can use the electricity instantaneously to offset your consumption, or whether you end up exporting it to the POCO at whatever rate they reimburse you.A system of X KW will generate Y value of electricity per year
Of course. The point I was originally trying to make was that it does not matter if you have a "small" electric bill, the payoff will still be the same as if you have a large electric bill. Of course there could be modifications to that based on a more complicated rate structure.But the value of Y depends on your local electricity rates, and whether you have net metering or can use the electricity instantaneously to offset your consumption, or whether you end up exporting it to the POCO at whatever rate they reimburse you.
Cheers, Wayne
That's only true if (a) your reimbursement rate for energy exported is the same as your avoided cost from not buying electricity from the POCO or (b) the PV system is small enough so that it never exports--i.e. your consumption is always large enough throughout the day even in the "small" electrical bill case. Or I guess also (c) your POCO uses buy all, sell all.it does not matter if you have a "small" electric bill, the payoff will still be the same as if you have a large electric bill.
Correct. Perhaps I should have been clear that I was just talking about simple net metering. I was speaking to the common fallacy that I hear that "I don't have a large electric bill so PV will never pay off for me."That's only true if (a) your reimbursement rate for energy exported is the same as your avoided cost from not buying electricity from the POCO or (b) the PV system is small enough so that it never exports--i.e. your consumption is always large enough throughout the day even in the "small" electrical bill case. Or I guess also (c) your POCO uses buy all, sell all.
Cheers, Wayne
Because our utility uses hydro, solar, unless they can really get the output and reliability much higher, it will not pay off for us. Where utility costs are much higher, such as California, then it could pay off. Maine is having to pay much high rates because of government regulations preventing use of hydro.Correct. Perhaps I should have been clear that I was just talking about simple net metering. I was speaking to the common fallacy that I hear that "I don't have a large electric bill so PV will never pay off for me."
Investigating solar is certainly good advice! Always get three bids from reputable local installers.Investigate a solar install carefully.
Iâve commissioned solar on our system and people spend 30k+ on these systems. For a $250 a month bill they could put the $30k in a 5 year CD and pay the power bill for 10+ years.
We have a 62 year old man that installed a $60k system on his house. He wonât live long enough to see a ROI.
Georgia Power doesnât allow net metering. You are paid the avoided energy rate, which for us is about 3.2¢ per kWh.
Unless they have changed in the last year..
The only people that I talk to that say they would do it again are those that are allowed to net meter. And not all of them want to go through it again.
I have a lady that bought a house with Solar on it. She wanted to get it up and running. This system had the micro investors under each panel. 2 out of 16 were working. She exported 2 kWh in 16 months.
Around here, PV systems are inspected by the POCO, so they would know.Not if they don't know![]()
But if you already have a system connected, the only way they would know if you added more is if they had the type of meter that could tell and alerts in their software or whatever to inform a human.Around here, PV systems are inspected by the POCO, so they would know.
In Austin and San Antonio the POCO requires permitting and inspection for adding to a PV system. Also, both POCOs require a dedicated PV meter that measures and reports PV system output irrespective of the load, so they would know if you added to the system. Beyond that, I am very much against hiding intentional rules violations even if "they would never know".But if you already have a system connected, the only way they would know if you added more is if they had the type of meter that could tell and alerts in their software or whatever to inform a human.
