I have spent years running only EMT, possible rigid.
I certainly will not use PVC conduit (the hard kind like sched 40 or 80 ) unless underground.
(As discussed in other threads it is terrible in UV, for PV installs on roofs. Absolutely @#$%.)
HOWEVER, I have a new love for LFNC. The gray, soft, flexible NON-metallic PVC stuff.
I find it cheap and quick. I use it for short jumps between equipment on walls, or at weird angles .......and for gaps between solar panels, say around a vent that forces a gap in solar array, I'll just slide some on the Enphase cable or PV wire.
No grounding bushings (bane of my existence) or even fittings on the ends. No need to pipe bend on roof.
However it looks tacky.
Opinions?
Is it a matter of workmanship/pride in work?
Quality?
Code?
Discuss!
Opinions?
Quality?
Code?
Discuss!
