snoogins1236
- Colorado
- Electrician
Hi , today I wired up a 240 volt well pump, with a neutral, and phase to phase I read 310 volts. One line has 240 to ground/ neutral and the other line has 120 to ground/ neutral.
It originates from a fused knife switch disconnect where I have good readings of 120 and 240 on both line and load. Further on the load side there is a controller with a capacitor Bank with relays that talk to the holding tank for the well pump. My instinct is that the capacitor is sending extra voltage on one of the lines but I can't be sure because of the type of pull out pins/ plugs that this controller has. I ran out of time today so I will get this thread some pictures tomorrow when I return but I was scratching my head. Thanks for any and all. Help/insight
