snoogins1236
- Colorado
- Electrician
But it is. All fixedI do? You literally just said "the capacitor is producing the increased voltage", which it's not, but...... Glad it's fixed.
The question now is, did they check the air pressure in the pressure tank???so it was working the whole time and you just thought it was broke?
Picky, Picky. I suppose you want egg in your beer, too?The question now is, did they check the air pressure in the pressure tank???![]()
Ha, it's responsible for a lot of pump failures.Picky, Picky. I suppose you want egg in your beer, too?
You put an egg in my beer and I'll punch you right in the mouth.....Picky, Picky. I suppose you want egg in your beer, too?
Not for me either!!You put an egg in my beer and I'll punch you right in the mouth.....![]()
I never liked tomato juice in it either but a lot of my friends did.
Second that! You know you on shi* beer when you need to add something to choke it down. Guinness Extra Stout is right for me.... Or a good TrippelYou put an egg in my beer and I'll punch you right in the mouth.....![]()
You don't have a Mid West accent!
Sorry man, I deal with pump guys all the time that don't understand these. That cap is NOT causing voltage rise, it's because the motor is running, causing back EMF, which is switching out the potential relay, as designed. I actually teach this stuff......to pump personnel. If that cap stays in circuit for more than about 2 seconds, it will explode.
You don't have a Mid West accent!![]()
My image of you has been dashed.I grabbed the first vid I could find as I am not about to waste the time to setup and make one just because someone wants to question me.
Facepalm, I should have just owned it and went all Aussie on ya.....My image of you has been dashed.
But you should have been more on point after my beer choices...lol I'm very German.My image of you has been dashed.
How is it not. I have seen 3phase pumps operated on a single phase supply with a cap bank set up to “add” if that’s the word you want to use an additional phase shift.??? That is not even a thing!
You do not believe in static phase converters???? That is not even a thing!
No, sorry, I already know when someone says something like that, no math was ever computed, no scopes were used, just a WAG. Yes, you can single phase a 3P motor, no problem, but you certainly will not get full power. With factoring, you are at 50%.How is it not. I have seen 3phase pumps operated on a single phase supply with a cap bank set up to “add” if that’s the word you want to use an additional phase shift.
I wouldn’t recommend it nor think it’s the best way around to do it.
Good to know.
Yes, i knew it was pumping and producing water to the tank but the 300v readings freaked me out and i didnt want to burn up the new motor pumpso it was working the whole time and you just thought it was broke?
