- Wisconsin
- PE (Retired) - Power Systems
Where did the discussion of drywall come from? Are you reaching for justification of your position?I not sure you are correct (and I am open for correction). Drywall is not an acceptable protection material. So if it's drywall then it should be evaluated as if there is no drywall,
My point was, if the location is called wet then all of the electrical installed must be suitable for wet locations, the plan inspector cannot say the panel needs to be rainproof but the switch does not.
