Residential Service Entrance Overhead Clearance
euclid43
I received a notice today about the overhead being too low in the backyard of a resident's property. I always thought that the requirement is at least 10 ft. high minimum. The notice from the power company wants it to be 12 feet high. There's no driveway in the yard, just grass. I've never been required to take it this high.
The utility uses the National Electrical Safety Code. I Though the clearance requirements were the same as in the NEC, but maybe not.
Why are you receiving a notice from the power company? Is the point of attachment too low? The drop does not fall under the NEC so it sounds like their problem not yours.
The point of attachment is 12 ft high. I agree with you on being their problem, thanks. I just thought that the minimum clearance is 10 anyway.
If the point of attachment is 12 ft that means that the low point of the sag is going to be less. You are responsible for installing the point of attachment, no? Probably what they are complaining about.
-Hal
Thus, circling back to 10 feet minimum.
