Scott K
- Boynton Beach, FL USA
Hello Everyone,
Has anyone else experienced this issue? I've been struggling with this issue of Eaton 1000 amp main breakers nuisance tripping. These are Double pole main breakers for apartment buildings on the East Coast of South Florida. This apt. complex has 19 buildings with 11 units each plus a house panel for each. The buildings are about 35 years old and Each building had the service replaced about 3 years ago. So far 3 of the buildings are having issues with the main breakers tripping for what seems to be no reason starting back in October of last year. Started with one building, then a couple months later the second building started and now a third started a couple weeks ago. We replaced 2 of the breakers with refurbished ones since we were told there is a 6 month lead time for new ones due to backorders. The refurbished worked fine for about 6 weeks and then started tripping like the others. We sent the 2 that we removed to Eaton for testing and just got back the results. The Breakers tested normal and no indication of nuisance tripping was discovered. Needless to say, the occupants of the buildings are irate! As the breakers are tripping at least once a day now. Seems mostly in the middle of the night but also happens in the daytime. FPL says it's not they're problem. If anyone can shed some light on this problem I would be so grateful.
Thank you in advance.
