30 amp Electric Range
The Copper Home range will
do everything you might want at 15 amps 120V. I understand you can even goose it up to 15 amps 240V for greater recovery.
That would be "Charlie", the first energy storage induction range.
It charges during off peak electric times, and is ready to put out 10kW for dinner.
All day canning not recommended: for that you need to be
For everybody else there's:
https://copperhome.com/products/charlie
...so.. you want set up your house so that it can only take a smaller wattage range, that basicly no one makes. Which means, in 5-10 years when it needs replaced, and no one makes them anymore that small, you will be married and forced to upgrade your wiring at that time?
Sounds like you should run a gas line instead of electric.
beat you to it in post #31 😇. The HO of a job im doing just got one. I have no idea why, he already had a 50A circuit installed.
These only need 120v
is $6k in your budget??
The founders took the Tesla route.... starting at the high-end luxury end of the market, with a prestige factor.
