30 amp Electric Range
The Copper Home range will
do everything you might want at 15 amps 120V. I understand you can even goose it up to 15 amps 240V for greater recovery.
That would be "Charlie", the first energy storage induction range.
It charges during off peak electric times, and is ready to put out 10kW for dinner.
All day canning not recommended: for that you need to be
For everybody else there's:
https://copperhome.com/products/charlie
...so.. you want set up your house so that it can only take a smaller wattage range, that basicly no one makes. Which means, in 5-10 years when it needs replaced, and no one makes them anymore that small, you will be married and forced to upgrade your wiring at that time?
Sounds like you should run a gas line instead of electric.
