Soffit lighting
nizak
Any suggestions on cutting 6 3/8” diameter holes in 26 gauge aluminum soffit material.
-hole saw
- shears
- roto zip
Thanks
I think a hole saw is the best option for a clean hole. That's what I've been using for vinyl soffits and it does make a perfect hole. I've also used tin snips in a pinch.
It seems that the pilot hole wants to enlarge in the very thin material. That makes the teeth want to wander.
I will try reverse and see if that helps. Thanks
