That’s what I have always done.Hole saw; try running it in reverse.
It seems that the pilot hole wants to enlarge in the very thin material. That makes the teeth want to wander.I think a hole saw is the best option for a clean hole. That's what I've been using for vinyl soffits and it does make a perfect hole. I've also used tin snips in a pinch.
Even with a 2x6 or something similar clamped behind the soffit?It seems that the pilot hole wants to enlarge in the very thin material. That makes the teeth want to wander.
I will try reverse and see if that helps. Thanks
How do you do that once it’s installed?Even with a 2x6 or something similar clamped behind the soffit?
