Cold weather vs Warm for residential rough in
nizak
Do any here charge more for residential rough in ( no heat) or the same price regardless of temps?
I bid a few large new builds back in May with the anticipation of rough in starting Mid August first September. GC is now telling me framing to start in November and rough in end of Nov/ First December.
I would any here re adjust price or just let it go?
Thanks
Northern MI
Some manufacturers have a caution about handling NM cable below 14°F.
Was doing a rough, a long time ago, using ENT when it came it 10' lengths and took the bundle out of the truck, inside, and dropped it on the concrete floor...it shattered into many many small pieces.
If it were me, I would have a clause in my contract about working below 20 deg F unless heat is provided. I would also include inclement weather and accessibility to the jobsite. I've seen some GCs who expect the subs to plow and shovel a path into the building.
-Hal
I think you're beat.
Here in KC, my favorite temps for new construction are low-mid 30s in the morning and highs around 50-55
I can get with it all the way down to about 20 degrees. I love the pace I can keep up when the temps are cold, because my body temperature rises quite a bit as I keep moving.
As already said, the working temperature of the cable is a concern below that.
