Cold weather vs Warm for residential rough in
nizak
Do any here charge more for residential rough in ( no heat) or the same price regardless of temps?
I bid a few large new builds back in May with the anticipation of rough in starting Mid August first September. GC is now telling me framing to start in November and rough in end of Nov/ First December.
I would any here re adjust price or just let it go?
Thanks
If it were me, I would have a clause in my contract about working below 20 deg F unless heat is provided. I would also include inclement weather and accessibility to the jobsite. I've seen some GCs who expect the subs to plow and shovel a path into the building.
-Hal
I think you're beat.
Here in KC, my favorite temps for new construction are low-mid 30s in the morning and highs around 50-55
I can get with it all the way down to about 20 degrees. I love the pace I can keep up when the temps are cold, because my body temperature rises quite a bit as I keep moving.
As already said, the working temperature of the cable is a concern below that.
I'm pretty much the same way. Can't take the heat and typically will get more done if it is 50-55. 20 degrees is usually fine for me as well as long as not out in the wind. I may bring a heater if it is going to be that cold but in non insulated building, forget trying to make it any more than 55 degrees you will go through a lot of fuel. If really cold might put a heater in basement and block off stairway to some degree to keep what heat you can down there and either work down there if possible or at least come back there now and then to warm up if needed.
"National Electrical Estimator" says their book and labor factors are based on good conditions of 50-85 degrees. I am sure other books and software have their own #s.
85 is a little warm for me. I would say 40-80 is good conditions for most.
But with me I would rather be warm than cold. Below 40 I can't do crap now my fingers don't work. Above 80 just slows me down.
Changes with age
I guess
Come on guys, us electricians already have this reputation as being prima donnas, lets not fuel that by saying its too cold. If I was hiring someone and they complained about it being too cold, I would find someone else who wasnt such a pansy.
New residential - we bring heaters in the winter. Typically 100-125k Kerosene Salamander type heaters. One or two depending on things. Yes it costs about $5/ gallon, but the productivity goes way up. We aren't rouging in 10 - 15 degree weather without heaters. We are in MA, and usually don't need them until mid to late December.
Hal makes a good point about access to the site. There is only one way I'm shoveling snow, it's when Hell freezes over!
But in the real world, productivity does go down when it is too hot or too cold. The actual temperatures that this happens varies from person to person.
True That!!!!! ten years ago my fingers would go numb, now they have arthritis and they will hurt like hell. (along with every other part of my body)
Personally, I hate those jobsite heaters. The noise and fumes drive me crazy. Again I just say if you're cold you're not wearing the right clothing. People need to learn how to dress for the conditions. There are people that live and work in far colder climates than we have here.
