Tap
Yes those can be used. I know that you mentioned a tap but with the conductors all being the same size what you actually have is a splice.
Ah, true? So would that change what's being used to join the conductors? Would some sort of splice kit be used instead of tap block?
To me, it lends itself more to a tap situation,
A 60 amp disconnect is not going to accept 1/0 conductors,
In any event, the ILSCO type connectors are a common solution. You just need to make sure the one you pick accommodates your conductor sizes.
