Alwayslearningelec
- NJ
- Estimator
Wouldn't the answer depend on the work rules for the General Contractor on the project?First question no, but
Second question yes
General contractor has work rules of his own?Wouldn't the answer depend on the work rules for the General Contractor on the project?
Absolutely.General contractor has work rules of his own?
Always, and if you don't understand those rules, you can lose a lot of money.General contractor has work rules of his own?
What his own rules in op case may?Always, and if you don't understand those rules, you can lose a lot of money.
A lot also depends on what your AHJ allows and the wiring methods. In much of my area, you can't run MC, Romex or pull wire in conduit until the building (or the floor) is "dried in".Really can't do much of any interior electrical work until after structural steel is complete correct? Or starting on floors above then you can work on floors below? It's a 3 story building.
Safety doesn't allow you to be working below someone. For example, you cant work on the floor if someone is working on the ceiling. Some GC's may try and push you to work below another trade but ultimately you are responsible for the safety of you and your workers.Wouldn't the answer depend on the work rules for the General Contractor on the project?
Material laydown areas, break trailer areas, working hours, and safety rules well beyond what OSHA requires, among others.What his own rules in op case may?
Please answer op two questions subject above constraintsMaterial laydown areas, break trailer areas, working hours, and safety rules well beyond what OSHA requires, among others.
My comments are in reference to post #3 and not post #1.Please answer op two questions subject above constraints
Can you explain a little more..thanksAlways, and if you don't understand those rules, you can lose a lot of money.
It can be anything that the GC wants from you. They set the conditions to work on the site.Can you explain a little more..thanks
