Alwayslearningelec
- NJ
- Estimator
Not sure they would know how to use theAn electric pallet jack, some qualified electricians, and some rigging equipment will work.
You wouldn't use a chain fall fore that size transformer. Toe jacks, pinch bars, Johnson bars, dunnage, skates, pipe rollers, etc.Not sure they would know how to use theng equipment ....you mean chain falls too?
In his other post, it is a cast coil which would be even heavier.Assuming dry type, you are looking at over 3,000lbs for that...
Someone I know said a forklift will get it off flatbed truckLike Don said conditions permitting get the operating engineer to drop it in place. Don't be like this doofus taking a photo.
Yes if the forklift is large enough that is what you would use to get it off of the truck. If you can drive to forklift to the final destination it can be set on the pad all in one shot.Someone I know said a forklift will get it off flatbed truck
Make sure it has fork lift pockets in the base...I did a couple that did not have that.Someone I know said a forklift will get it off flatbed truck
