woody75
- Chicago, IL, USA
In a modern bathroom with PVC plumbing, how much protection does GFCI protected circuits provide?
Example: Lets say you're in the bathtub and a plugged-in hair dryer falls into the tub. In a modern residential house and bathroom that uses all plastic piping, where would the power drain to for the GFCI to trip? Even if you are sitting in a half-tub of water, the drain plumbing and water plumbing attached to the fiberglass tub wouldn't provide a path to ground... Light fixtures in shower stalls, small appliances on the sink, all sources of live power that should be GFCI protected, but without a path to ground while sitting in the water, would the GFCI function as intended? Is there a sufficient enough ground in plastic plumbing to trip a GFCI?
