Our go-to measuring device is eGauge with CT's. Which (if you are not familiar) allows us to send the load data in real time to a website where we can watch it, and also keep it on for months at a time, then be able to go back and look through months of data.
I do not know the specifics in terms of frequency response, or true-rms capabilities. But that might be worth me looking into to find out.
The outside company we hired to do the testing did use an oscilloscope as well as a handful of other tests, all of which apparently led them to tell us the disconnect was the problem. They then suggested we upsize it to the 200A HD disconnect...and here we are several years later.
However, i wouldnt be opposed to us buying our own oscilloscope for our crew, do you have a brand/model you recommend?
From what i have learned in my career is that there is
always a chance that something may be programmed to do something unexpected haha. So while i dont believe the VFD may be operating under single phase conditions, i think it is absolutely worth looking into the next time we are there.
However, my coworker just told me (i am usually texting him to get these answers so i can reply to you guys in as timely a manner as i can
) that originally the soft start that was hooked up to the fan motor would occasionally throw an error code and stop working. This led the fan contractor to ask us to install the VFD that we are now using.
So i assume that the problem is hopefully not with the VFD, but whatever was causing the soft start to fail is likely the culprit?
I really do apologize for not having all the information readily available, as i have mentioned quite a bit now, i wasnt the actual installer, and the last time i had any thought about this was at least 3 years ago. So its all coming back into memory as my coworker and i discuss this and retrace steps.
Thanks!
