Would GFCI protection be required for an indoor dry sauna.
It’s located in an unfinished basement. It’s hardwired with a 6-2 SO cord and a disconnect.
It is a 9 KW 240 V unit that is being housed inside a homemade cedar enclosure.
The Mfgr cut sheet only says to provide electrical that meets local codes. Says nothing else other than power requirements of 48-52 amps. 240V
The unit is manufactured in Australia and marketed through a Company in the U.S.
Because it’s in the unfinished basement space is that what would be requiring the GFCI protection if it does.
Thank you.
Thank you.
