Where in NEC do we learn limits of modifications?
Not sure I understand what limits of modifications means. Boxes can be punched, many come with no holes in them at all. You can always installed an extension box to increase the number of conductors allowed.If you pulling 10 AWGs 3/4 accomplishes as many circuits as 1” so those 4 squares would serve only the purpose of pulling larger wire.
I guess I’m wondering what we are “supposed” to do. Lookup to ul listing on each box/enclosure and see if they allow us to punch holes in boxes that have predetermined knockouts?Not sure I understand what limits of modifications means. Boxes can be punched, many come with no holes in them at all. You can always installed an extension box to increase the number of conductors allowed.
No. Just go ahead and punch them!I guess I’m wondering what we are “supposed” to do. Lookup to ul listing on each box/enclosure and see if they allow us to punch holes in boxes that have predetermined knockouts?
And don’t look back.No. Just go ahead and punch them!
-Hal
yup. The are octagonal with 1" kos too.They make 4" squares with 1" K.O.'s
They definately make 4 11/16 w/1" and .75. Not aure ive seen premade 4sq with 1" but ive punched them out- drilling is a hassle, even with tko bitsThey make 4" squares with 1" K.O.'s
Just glad to see the strut caps. Many of lives saved thereI did this recently and used 4 sq's with 1" KOs. ITs just a full boat of #12's in one and a couple cat6 in the other, I just like to use 1" for these drops b/c 3/4 seems a little flimsy.
Looks nice!I did this recently and used 4 sq's with 1" KOs. ITs just a full boat of #12's in one and a couple cat6 in the other, I just like to use 1" for these drops b/c 3/4 seems a little flimsy.
In the company I work for, guys will knockout or drill out a hole for a 1” emt into a four square. I think even as a pull box you would be over on a full boat 10 AWG pull, but what is the legality of such a modification?
Depot started spec’ing 1” drops a few years back on new stores, don’t know if they still do. Quite a bit more expensive than 1/2” with that many drops. Not much is going to hold up to a misplaced pallet though! LOL!I did this recently and used 4 sq's with 1" KOs. ITs just a full boat of #12's in one and a couple cat6 in the other, I just like to use 1" for these drops b/c 3/4 seems a little flimsy.
Although it looks good and I have no issue with it, isn't there a violation of 300.11(C) Raceways Used as Means of Support?I did this recently and used 4 sq's with 1" KOs. ITs just a full boat of #12's in one and a couple cat6 in the other, I just like to use 1" for these drops b/c 3/4 seems a little flimsy.
You mean the raceways supporting the regulators? Yes that's a violation.Although it looks good and I have no issue with it, isn't there a violation of 300.11(C) Raceways Used as Means of Support?
Mark
Mark
I dont see any violation. I "identified" the raceway as a means of support.You mean the raceways supporting the regulators? Yes that's a violation.
