Sierrasparky
- USA
- Electrician ,contractor
Hello,
I am not a solar contractor however I would like to understand the methodology in calculating new loads when a PV system is installed and the Main breaker size is reduced to accommodate a larger array?
Example is you have a 200a all in one and you reduce the main breaker to 150 in order to have a greater back-feed. I want to know what the new panel rating is for load calculations is. Is it still a 200a or a ?
