Isnt this a perfect example of the code contradicting itself?
The National Electrical Code (NEC) allows a neutral-to-ground connection for ranges
on existing installations using 3-wire circuits, which was originally permitted to save wire during World War II and was continued by the manufacturers. However, for new construction, the NEC requires a 4-wire circuit with a separate neutral and ground conductor for safety, as bonding the two can be dangerous in case of a fault.
