Eddie702
Licensed Electrician
- Western Massachusetts
- Electrician
Even in a house I usually like the switches at 42". Don't know why I just thought 48" was too high
It’s usually to make it easier on the Sheetrock hangers. I don’t think the finishers like it that much though.Even in a house I usually like the switches at 42". Don't know why I just thought 48" was too high
Based on what? Local code amendment?KCMO metro code enforced 4' in garages and basements. Always. Or unfinished spaces as well.
Yes. I don't believe NEC says anything about 4'.Based on what? Local code amendment?
Yes the NEC has no height requirement for these receptacles so if a jurisdiction is requiring the receptacles to be installed at a certain minimum height in dwelling garaged then it would have to be required by a local amendment.Yes. I don't believe NEC says anything about 4'.
And the NJ DCA, through the UCC is the only body in NJ that's allowed to do that.Yes the NEC has no height requirement for these receptacles so if a jurisdiction is requiring the receptacles to be installed at a certain minimum height in dwelling garaged then it would have to be required by a local amendment.
