fastline
- midwest usa
- Engineer
So now we are comparing the "tolerance" of carbon film axial lead resistors, to an immersion heater? You do realize what that "tolerance" really means, and the dR of even those carbon resistors changes substantially with heat? Like I design PCBs and that is something that has to get factored!Do you believe that the 6.28 ohm combined heating elements are going to change by like 1.2 ohms or something. Of course it works by percentages.
This is all basic electrical theory taught in 8th grade. The numbers are all so small as to be insignificant. and if it isn't as hot the resistance will be lower so it will draw more current, but not enough in this application to mean anything.f it was a manufacturing tolerance it woukl
I'll bet manufacturing tolerances are wider than what difference is caused by the small temperature changes in the element cause.
Hell it's so small a difference in percentage of resistance it'd be in the gold
View attachment 2580986View attachment 2580987
The current in a wound Nichrome element is a function of it't temp. The current in a single piece of of Nichrome can vary by 10% just within a 200*F window of operating temp! That is NOT fluid temp, that is the wire temp. How do you know the operating resistance of a wound element? Precise measurement of applied voltage and observed current.
