SEW EURO DRIVE 12 Lead Motor
Saturn_Europa
Fishing Industry
Electrician Limited License NC, QMED Electrician
I am wiring up a 10 hp 3 phase motor to 480v. Its an IEC 12 lead motor. The data sheet is attached. There are two sets of each: RED BLACK BLUE wires and WHITE BROWN YELLOW wires. For a total of 12 wires. None of the wires are labeled.
The wiring options are Delta and Double Delta.
Which wiring option is for High Voltage?
I could not read the markings in the upper drawing but you might want to first talk to your motor repair company that might ask you to drop this motor off for them to figure out. At my first job we only had 240 volts three power for motors ( fractional to 200 HP ). When we had motors rewound we had the motor rewind shop connect every motor for 240 volts and only bring three leads into pecker heads.
The single delta connection that @Joethemechanic highlighted is the high voltage connection.
The problem is that the 'datasheet' doesn't tell you the wire colors; it only gives terminal numbers. All of the wiring diagrams that I can find point to numbers on terminal blocks, not color coded wire leads.
The motor was stored in a wooden box that was too small for the motor termination box to fit in. So they pulled the termination box and the copper studs that the ring terminals land on. I found another spare that still had motor terminal box on it and I am pretty sure I have it wired correctly now. The problem is the wires are not labelled at all. It took a bit of guess work. But I think its wired correctly now.
Just a guess, two of each color is possibly same color for each end of one winding coil? Can verify that with continuity checks I guess.
Still need to figure out correct polarity and which coils need to be in series with one another.
Easier yet would be if the colors are for identifying polarity, say black red blue were one end of two of three individual coils, and brown yellow white were other end you could apply 240 volts to just one set and run the motor (no load on the shaft) and check to see if it runs with equal currents and verify rotation. Chances are if that works you have one of the two delta's figured out and you should be able to connect the other set parallel to it in the same configuration which is how both deltas need connected for 240 volts. Then you just need keep track of the sets and connect them in series instead of parallel. If you get wrong polarity on just one of the six windings it probably runs but will have counter torque on the one coil that has reversed polarity and a current imbalance because of it. Once you get it to where it runs with balanced current it should be connected correctly.
It's kind of embarrising. I've replaced and rebuilt lots of their gear motors, new bearings, seals, combining parts from the old ones, along with a new one to get the configuration I need in a pinch. But damned if I can remember wire colors. I even remember 380 volt wye connections. They are very popular motors in automated food production.
One think I can tell you for sure is, those insulated ring terminals are not factory. Somebody was into that motor
I wired it up and it doesn’t turn. Just hums loudly until I turn it off.
I’ll send some pictures when I’m back on shift. Kind of a bummer.
That pretty much means that some phases are inverted or swapped, or you have bad windings.
If you assume that the motor isn't broken but you've lost the information to connect it properly, then you can follow a procedure sometimes called 'ringing out' the motor.
I've found a step by step for a 9 lead motor, but not for a 12 lead:
I'll poke a bit to see if I can find a 12 lead procedure online...I probably saw it in an old textbook
How many leads coming off this stator? How are they grouped up when you unwire everything you can see and test conductivity between them with your meter?
This is a gearmotor for a conveyor in a factory ship right?
If you can see what colors go together that's probably 75% of the puzzle. Now how to find the polarity. Does it look like blue and blue, for instance is a winding or do the windings have different colors at each end? Easy enough to find out with an ohm meter.
-Hal
-Hal
Yep!! Blue to Blue is wired thru one of the windings. I pulled apart a similar motor termination box and found that I had the blue wires reversed on the motor.
It fired right up.
Such a pain. All because someone couldn't be bothered to build the right size wooden box!
If line voltage is wired to thermal sensor, will failure to start occur, or just sensor damage?
I think I only worked on one machine (an oven) where the thermal sensors were hooked up. If I remember right the thermal sensor wires were smaller than the armature leads, on the larger motors.
We had a lot of those motors in the store room that had the sensors, but we really didn't need them for most applications, so we just used them without the sensor hooked up. No idea why they ordered them that way, but it was a multinational with lots of plants.
